Having problem with my 93 ex HELLLPP!!!!!!!
Old Oct 9, 2009 | 07:21 AM
DeDonDeRosa's Avatar
Default Having problem with my 93 ex HELLLPP!!!!!!!
OK well i have a 93 civic ex all stock and heres the prob.....
1. get in car, started right up...
2. 2 miles down the road it stalled.....
3. car started back up.... ran to 2 min as i was driving again then stalled again now wont start....
4. this has happened to me a couple timese b4 tooo.... if i let it sit for a lil while it ususally starts up again... but this time idk how long it may run.... thats if it starts
ok so i got it started it stalled on me 2wice on my 1 mile trip home.... i got it up to normal temps and now its fine.... what would cause this stallilng when its cold i dont get it ..... it seems to be fine for now when its at normal temp
help me out what u think it could be
AND THERE ARE NO CELS......
Old Oct 9, 2009 | 07:31 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: Having problem with my 93 ex HELLLPP!!!!!!!
change your topic title to sumthing specific
any cels?
does it sound like a fuel or ignition problem
Old Oct 9, 2009 | 08:30 AM
Former User's Avatar
Some common possible causes -- main relay, coil, igniter unit.
When the engine won't start, listen for whether the fuel pump fails to prime and check whether there is no bright white spark at the plugs.
Old Oct 9, 2009 | 08:39 AM
Simkin314's Avatar
Agreed, I had a similar problem with the main relay: tapped/kicked it to get it started again.
I had a similar problem with the igniter unit: One of the wire leads broke free in the epoxy (so it slid around causing an intermittent problem) This was in a NEW distributor (it wasn't made for colder climates)
Old Oct 9, 2009 | 10:28 AM
KylesEgHatch's Avatar
Check out your ground wires.
Old Oct 9, 2009 | 10:45 AM
yea fuel pump primes fine every time....... and it cranks but wont kick over
Old Oct 9, 2009 | 10:48 AM
civicb16eg's Avatar
Sounds like igniter
Old Oct 9, 2009 | 10:51 AM
Engine/Chassis ground. Try it out. Your igniter sounds very reasonable as well.
Old Oct 9, 2009 | 11:09 AM
Check for bright white spark at the plugs.
If you don't have spark, check the igniter unit and coil and whether the timing belt snapped.
If you have spark, check whether the timing belt skipped some teeth.
Old Oct 9, 2009 | 11:41 AM
itsnotfast's Avatar
...kicked it to get it started again.QUOTE]
LOL thats great. The perfect fix..
Old Oct 9, 2009 | 11:43 AM
itsnotfast's Avatar
My EK had the same problem when I got it.
Dahhhbeed
Aug 15, 2016 04:55 AM
LandHard
Apr 3, 2015 04:37 PM
DeDonDeRosa
Oct 9, 2009 11:21 AM
WEEZY034
Jul 28, 2008 05:16 AM
DAVE15401
Jan 24, 2005 10:40 AM
