Huge List Honda/Acura Parts Shipping available 92-95/94-01/96-00/88-91
I can ship any and all parts, combine shipping, or go through ebay how ever you want to do it. Paypal payments add 1.00 to cover some of the fees, ebay auctions add 12% to cover ebay fees. If your wanting something shipped feel free to text, or pm me with what you are wanting and your zip code. I will ship with tracking through ups or usps all items will have valid tracking, insurance optional, but included if under 100.00 through ups. Not here to rip anyone off. Just looking to clean out my garage a bit. Pictures can be supplied upon request.
All items located 35miles east of Indianapolis, IN
96-00 civic parts
dark grey driver side door panel speaker cover 10.00
Steering wheel cruise control switch 7.00
(hatch) rear speaker covers, originally dgrey were spray painted red, then one painted flat black, 10each, paint stripper or flat black spray paint will make them match to the dark grey interior.
ds lower kick panel dark grey 15.00
ps outside door pillar plastic piece 10.00
lower dash panel under your steering wheel that holds your coin pocket, and fuse box cover i have 2 in dark grey 1 in light grey 12 each
y7 intake manifold w/ injectors 20.00
Gas door and trunk popper levers 10.00
y7 throttle body complete 20.00
99-00 cup holder (does not have top cover, but will bolt up fine in any 96-00)
Front end headlight harness for both headlights all the way across the front end 25.00
94-01 integra
Headlight control switch 15.00
ls obd2 center timing belt cover (not lower, just center piece that mounts to valve cover) 10.00
steering wheel cruise control switch 7.00
tan ebrake 10.00
tan arm rest center console 15 complete, 10 just the top
4d green gas door (has some scratches) 8.00
obd2 ls intake manifold with injectors 20.00
obd1 shaved green powdercoated valve cover (never been on a running car) 35.00
92-95 civic
both ds & ps interior door handles (2d/3d) without lock buttons 8.00 per side 15.00 for both
1.5l non vtec ds top engine mount 10.00 (2 bolts on the block)
1.6l ds top engine mount 15.00 (3bolts on the block will work d/b series)
power mirror dash switch 8.00
under radio dash panel that holds your lighter, ash tray and coin tray in BLUE 15.00 complete
Grey oem armrest (leather like top, not cloth) 2 bolt holes plastic is broken, 2 larger washers and a larger bolt and you'll never have a problem with it 20.00
88-91 civic
OEM honda radio antenna block off plate, includes gasket & 2 screws 10.00
driver side manual mirror (oem black, not painted) 15.00
light dimmer dash button 7.00
rear defrost & light dimmer 10.00
1 steelie oem H center cap 6.00
hazard switch 7.00
rear defrost switch 7.00
5spd d series transmission (bought it from a junk yard car i pulled it from had 112k miles on it and i never used it) 80.00, shipping will be very high on this, pick up is preferred.
I have several other interior parts, if interested in pick up only items I have several interior panel pieces off a 96-00 civic hatch and a 99-00 si coupe, as well as rear si seats, integra tan cloth seats, civic lt grey seats, and many other parts. Will be adding more daily as i get it down from the garage.
ways to contact, send a message through here
email: Buildingboost@comcast.net
Txt: 765 220 1677
prices are firm unless many items are purchased at the same time.
96-00 civic parts
94-01 integra
tan ebrake 10.00
92-95 civic
88-91 civic
hazard switch 7.00
Txt: 765 220 1677
ClubDownforce
Sep 5, 2007 06:44 PM
