95 ex h22a1 swap wiring help
Old Oct 8, 2009 | 02:51 PM
tichal2008's Avatar
Default 95 ex h22a1 swap wiring help
i have a few questions. first let me start by telling you i have the d16z6 harness and the full prelude harness. i also have the p13 and jdm p72. i was wondering if someone could tell me how i should go about wiring this. i read different things. so do i mount the d series harness on the h motor and then figure out what extra connections i need and extend. also i dont know if this is right but should i plug the h harness into the h ecu then cut about 8-10" of the h harness then start wiring the d harness into the h. that way whatever wires i have left from the h harness that are not wired up will be for the extra sensors on the new prelude motor. if im wrong pls help. ive read so much on this swap but get confused because everybody does the h22a and not the hh2a1 dont know if there is a difference just want a straight forward answer if anyone has pics of this swap or wiring pls post. thanks
99exd16y8
Apr 6, 2005 04:26 PM
