high hp guys, what do you use for tranny fluid???
I'm needing some input on what tranny fluid everyone is running on your high hp setup. I'm currently running a stock tranny w/stock lsd. Any input is appreciated. I've tried searching, but nothing. high hp guys, what do you use for tranny fluid???
With the PPG and Amsoil the shift is very smooth and it's actually pretty quiet for the type of trans that it is.... Never ran it on the Liberty I had so I have nothing to compare to....
I ran Royal Purple synchromesh for the last couple years without issues. recently switched over to Torco RTF and its pretty nice. Still on the stock trans for the moment.
and steve yes, shock proof frikin stinks. we use it in all the shelbys with tranny brakes.
Good info... I've been wanting to try that Royal Purple synchromesh, but hadnt heard from anyone else using it... Might have to get some for my new trans. and try it out...
we use the red line red color. pain in the *** to get in our trans takes about 30 kin just to feed 5 quarts in. dont they also make a green?
dont think it stinks that much just a biotch to clean up.
For those running the stock synchronous trans, won't this stuff be a bit harsh on the synchros? Or would that assumption be overstated? I'd like to try it, but I'm a bit hesitant to run it on my trans given the additives in it are probably going to burn through the brass.
