Swapping ZC/D16 Injectors, advice needed!
Hello guys, so I put a ZC in my EF civic not too long ago, but since the harnesses are different I reused my original intake manifold off of the original motor (including the injectors) so I could use my original harness. I want to now swap my old injectors with the ones that came with the zc. By the looks of the clips they are the same thing.... so can I just swap the injectors and be done? I thought the ZC was high impedence or vice cersa and they had different clips but they look the same..
Thank you!
Aaron
Thank you!
Aaron
If im not mistaken you should be able to use the stock injectors that came with the zc. I belive on usdm EDs and jdm EFs that are multi point fuel injection you have a injector resistor box that is on the drivers side by the flat part of the shock tower. So you should be good to go
miketurbohonda
Nov 27, 2004 06:12 AM
