b18c build
Old Oct 8, 2009 | 09:53 AM
NOSKID22's Avatar
Default b18c build
wanted to know wat to expect form my current setup any help would be great
BLOCK
LS rods & Crank
ctr pistons
arp rod bolts
2ply head gasket
HEAD
B16 head(milled (.020)
gsr cams
ctr IM
b16 TB
itr fuel pump
290cc injectors
hopin to make 180 with current setup
Old Oct 8, 2009 | 10:05 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: b18c build
The e-dyno is closed. (check forum rules.)
Now, if you would like some advise, I would recommend that you find some bigger cams or go with ITR pistons. Low octane, high compression, poor flame travel, and small pistons, equate to a failed, poor performing engine.
Old Oct 9, 2009 | 09:09 AM
all-mtr-teg's Avatar
Stock GSR cams and stock B16 IM, I doubt you'll make 180 whp. Perhaps 180 flywheel hp if you build it well. Like mentioned about, CTR pistons are the last pistons you should be looking at. PR3 pistons would be plenty.
Old Oct 9, 2009 | 09:23 AM
roycivic92's Avatar
wow
Old Mar 11, 2010 | 07:04 PM
EK_COUPE_0515's Avatar
TRIAL USER
haha... why did u go with the LS rods and crank?
kaane21
Aug 30, 2011 07:37 AM
Tweek-B16
Nov 28, 2008 09:13 AM
Pr0j3ctxH@tchx90
12
Jul 11, 2007 09:16 AM
chngeovr99
Jun 8, 2006 06:17 PM
TypeR0wnz
Feb 15, 2003 03:06 PM
