clutch "depressurizing"
Old Oct 8, 2009 | 07:28 AM
hannslebo's Avatar
Default clutch "depressurizing"
what happens when that happens??
Old Oct 8, 2009 | 08:02 AM
blaze_125's Avatar
Default Re: clutch "depressurizing"
got leaks?
is there still fluid in the slave cylinder?
Old Oct 8, 2009 | 08:43 AM
Unseen Racer's Avatar
you may have a leak in the clutch lines or a bubble as well.
bleed your clutch lines to remove any bubbles and clean all exterior clutch line parts
including the clutch master cylinder. then check for leaks
Old Oct 8, 2009 | 09:21 AM
DC2-ProdUcTiOnS's Avatar
From: Howcome we park on driveways, and drive on parkways?
replace slave cylinder
Old Oct 8, 2009 | 10:03 AM
98y8's Avatar
this happened to me in my z24. my slave cylinder was broken.
Old Oct 8, 2009 | 11:22 AM
EcivicG's Avatar
not to threadjack the OP's question but i have a 93 ej2 and whenever i depress the clutch, it kinda squeaks a little bit, and it didn't do that before until winter of last year when it started to get colder.
any info?
Old Oct 8, 2009 | 04:44 PM
any info?
spray WD-40 on the clutch pedeal assembly?
sohctodohc
Mar 5, 2006 02:10 PM
MugenHonda
Jun 27, 2005 08:00 AM
FLCivic
Jun 30, 2004 03:48 PM
g00se
Mar 8, 2004 06:11 PM
myhatchrips
Dec 5, 2003 07:21 AM
