FS: 93 EG Hatch DX (Gainesville)
1993 Honda Civic Hatchback DX – Milano Red
$4000 OBO
For additional information, please contact me at (954) 326-0230.
SERIOUS INQUIRIES ONLY PLEASE
-NO LOW BALLING
-NOT PARTING OUT
The car was originally an automatic but we did a manual swap on it.
The chassis has about 111,600 miles and motor has about 70,000 miles.
The fuel filter, water pump and timing belt were changed at about 50,000 miles.
Car runs very well.
Alarm:
Clifford 700 w/ Black Jax (Carbon Fiber Remote)
Engine:
‘00 Turbo (10 lbs.) Stock LS Motor (B18B) w/ GS-R transmission
Stock GSR Flywheel w/ XCT 6-Puck Clutch
APEXi World Sport I Exhaust (2.25”)
2.5” Test Pipe
Skunk 2 Intake Manifold
OEM Front Integra Strut Bar
NGK Blue Spark Plug Wires
NGK Spark Plugs
Fuel Filter Gauge
Polished Valve Cover
RC550 Injectors
Walbro 255 LPH-HP Fuel Pump
JDMSH!T Automatic-Manual Transmission Mount
HAAS Sport Polished Side Mount
DC Sports Oil Cap
No power steering pump but the pipe is still in the motor
Turbo:
Turbonetics Drag Kit
Drag High Flow 4-1 Cast Iron Turbo Exhaust Manifold
Turbonetics T3/T4 High-Flow Turbocharger Assembly
Turbosmart Street-Gate 38 w/ 10 lb. Spring
Drag High Flow front mount intercooler w/
polished cast aluminum end tanks
GReddy Blow Off Valve
Drag mandrel bent high flow chrome plated intercooler pipes
Drag mandrel bent high flow exhaust down pipe
Drag wastegate dump tube assembly
Drag Blue silicone hose and hose clamps
Drag High pressure/High volume inline fuel pump
Drag Boost dependent FMU fuel regulator
Intake Air Filter
Map Sensor Bypass Valve Assembly
Stainless steel braided oil feed line w/ fittings
Oil return assembly
All necessary hardware and fittings
All necessary hose and hose clamps
All necessary gaskets
Interior:
Tinted Windows
Dual Gauge Pod w/ DFI Lookalike Boost and Volt Gauges
Black w/ Red Stripes Del Sol Seats (Civic Rails)
Rear OEM Black Civic Hatchback Seats
Integra Steering Wheel
Integra Dash
OEM Floor Mats
Civic Modified Door Panels to Fit Dash w/ Red Felt Side Panels
Power Windows and Door Locks
Integra Type-R (Red Stitching) Shift Boot
Pioneer DEH-P4000 Radio w/ Sony Explod Speakers (Front)/ Stock Speakers (Rear)
-Comes with Steering Wheel Remote
Exterior:
16” White Rota Track R Wheels w/ Sprint Hart Stickers
Falcon Ziex ZE512 205/45/R16 Tires w/ 70%-60% Tread Life
Extended Red Lug Nuts
Mugen WWRS Lookalike Lip
Carbon Fiber Duck Bill Wing
Spoon Lookalike Mirrors (Blue Tinted)
JDM Headlights (H4H Housing) w/ 5000k HID Lights (Philips Ballast)
JDM Corner Lights
OEM Window Visors
Porsche 911 Turbo Emblem
Datum 1 Tow Hook
Suspension/Brakes:
Ground Control Coilovers w/ AGX Shocks
4-Way Adjustable (F)/ 8-Way Adjustable (R)
Integra GSR F/R Brake Suspension w/ Calipers painted Gold
Brembo OEM Rotors (F/R)
Hawk Racing Brake Pads (Blue)
Stainless Steel Brake Lines
OEM Acura CL Brake Booster w/ Spoon Reservoir Cover
Aftermarket Front Camber Kit/Washers in Rear
Front/Rear Integra Sway Bars
Car Needs:
Paint Job
A/C Fixed
TPS Fixed
$4000 OBO
-NO LOW BALLING
-NOT PARTING OUT
Car runs very well.
Alarm:
Engine:
2.5” Test Pipe
NGK Spark Plugs
Fuel Filter Gauge
RC550 Injectors
DC Sports Oil Cap
Turbo:
Intake Air Filter
Oil return assembly
Interior:
Tinted Windows
Integra Dash
OEM Floor Mats
Exterior:
JDM Corner Lights
OEM Window Visors
Datum 1 Tow Hook
Suspension/Brakes:
Car Needs:
Paint Job
A/C Fixed
TPS Fixed
