Timing Belt Broke Help!!!!
Here's the situation i was on the freeway had to vtec it a little to get on the freeway without getting runned over, while on third gear...i then take some quick shifts to fifth gear i drive it for like 5-10 seconds and feel my car pull me back...pull over to the side of the road and cars dead just rolling to the side of the road so i stop i had a feeling it was the timing belt and there it was my timing belts gone....no radiator water leaking so i hope i didn't bust a cap in my block...but wat are some possibilitys i might have to look into when putting in a new timing belt and water pump...im going to do a compression test also but does it seem bad guys...im no honda guru so im asking anyone please help...also can someone give me the link to timing belt and waterpump changing..thanks
What I'm trying to say is .. are you sure your timing belt is gone ? You might be looking at a different belt for all I know.
did you remove valve cover to diagnose this ? or remove timing cover ? .. how are you able to pull over, pop your hood, and say to yourself "Yes, its my timing belt, its gone" ??
You can try the timing set & see if you get lucky, but I'd go on & pull the head & have it checked, your block is probably OK unless a valve punched a hole in a piston
Had a similar thing happen to me only mine broke moving from a dead stop at a stop light. The bad thing is that H22 are zero clearance engines and you more than likely have bent a valve. The only way to know for sure is to put a new belt on. (If you are doing it yourself you are in for a treat.) Then check the compression on each cylinder. When mine went out I also switched to a manual timing belt tensioner which works better than the hydrolic ones that come on the H22's. I did the work all myself so if you have any questions let me know.
so were can i locate a manual tensioner...would that be the ones off the h23 and it would just be the tensioner i need or would i have to change a couple things around alsoand does anyone know of a way to get a write up with some pics..im actually doing it by myself i just found some time today to take off the valve cover cams are off...thanks guys
the best thing to do is get a service manual for the prelude it'll walk you step by step. i got one off of e-bay that was downloaded to my computer for about $10. Yes, the manual tensioner comes off of the h23. The crankshaft pulley bolt is a beast unless you have an impact wrench. I have some write ups on the tensioner on my home computer I'll try to post later.
00siALLmotor
Acura TL, RL & ZDX
Jan 30, 2005 09:31 PM
