270cc injectors in stock b16
my obd0 b16 came with 270cc injectors in it and it runs fine just smokes a little. i think some of the smoke is from only having 1 o2 sensor and both wires are wired to the same sensor, so its running ritch to start with. the onlt thing done to the engine is gsr cams, i/e. its in a 89si. so my question is do i need to change injectors or should getting a second o2 sensor take care of it?
is your ecu chipped!? if so take it to your tuner and tell him to change the injector size on the ecu!! or if you got hondata you can do it yourself!! dont know if you wana try that or just change em to 240's again!!!
Down Shift Motoring
19
Dec 14, 2005 03:35 PM
FullRaceTurboSi
Apr 13, 2005 03:37 PM
