D16Z6 Swap
Old Oct 7, 2009 | 05:14 AM
tech410's Avatar
Default D16Z6 Swap
I am currently in the process of doing a swap. I have the OBD0 to OBD1 conversion harness. Now my question is: "Do I use my original HF engine harness?" Will the plugs work on a VTEC head? Any help with this is appreciated. Thanks!
Old Oct 7, 2009 | 06:23 AM
dephtone's Avatar
Default Re: D16Z6 Swap
Yes everything will plug in for the most part, there might be a plug or 2 that won't plug in but this is normal. o2 will not have a place to be plugged in as obd0 uses a 1 wire and obd1 uses a 4 wire.
The conversion harness will have wires for you to run to the VTEC solenoid, Pressure Switch, 4 wire o2, etc.
Old Oct 7, 2009 | 08:31 PM
tech410's Avatar
Is there a post or sticky of the HF engine harness diagram on this forum? I tried searching and no luck. I want to know what each plug or connector is for. Thanks for the reply dephtone!
Old Oct 7, 2009 | 09:21 PM
BiG ChOr!Zo's Avatar
try looking in the FAQ 2.0 thread on the main page...!!!
goba
Jul 29, 2010 12:35 PM
h22-hatch
Mar 8, 2010 10:09 AM
arrojj
Jan 3, 2007 07:54 PM
Serdar
16
Sep 6, 2006 09:11 AM
TGrant
Apr 19, 2006 02:25 PM
