obd2 to obd1 distributor question
if you do an obd2 to obd1 conversion i've read that you have to change the distributor, my question is if you use to accel 300+ system that turns your distributor into an external coil distributor can you use that set up? or will it still not work?
Thanks.
Thanks.
ej8_fredi
Mar 28, 2009 11:10 PM
Astr8upfella
Jan 20, 2002 01:30 PM
