Clean Intake Control Valve now Idle is High
Old Oct 6, 2009 | 07:09 PM
bopbop93030's Avatar
Default Clean Intake Control Valve now Idle is High
2000 Civic DX
I have cleaned the ICV and now my idle is very high and not the same as before.
Do I need to adjust idle or there is something wrong?
If it helps I took the ICV out and there is a coolant leak
Help!
Thanks.
Old Oct 6, 2009 | 07:29 PM
gwl's Avatar
gwl
Default Re: Clean Intake Control Valve now Idle is High
Coolants runs through the IACV. Make sure you properly bleed the air out of your cooling system.
Old Oct 6, 2009 | 07:35 PM
How?
Thats probably the problem is.
Old Oct 6, 2009 | 07:36 PM
Do I need to go down in the radiator and flush the coolant?
Old Oct 6, 2009 | 07:40 PM
Suzukifreek's Avatar
There will be a Bleeder screw on the thermostat housing. Open that up and let the motor run. Wait till coolant comes out then close it. Good luck pm if you got any more questions.
Old Oct 6, 2009 | 11:45 PM
Is there a picture that I can see.
xlusiveracer
40
Jan 23, 2017 09:32 PM
Ef4doorwagon
17
Apr 6, 2014 03:31 PM
B*Goods*EJ2
May 3, 2010 07:15 PM
huge230
Mar 29, 2006 05:19 PM
REDBARON
Oct 9, 2001 12:10 PM
