My Nonvtec B22b frankenstein
1st i want apologise myself for my bad english...
I started the motor last fryday, ill be street tuned tomorow and Dynoed soon
I want you guy's opinion on the power it can do wit that set up
The set up:
-B20 84.5 DART bloc 226mm deck hight
-97mm Eagle restroked crank ( 2.180L)
-151mm Rods
-Flat pistons -4cc notch for 11.4:1 P8R head shaved .020
-P8R head Ported/flowed at:
- 252CFM@.500 Lift
- 229CFM@.400 Lift
- 196CFM@.300 Lift
- 157CFM@.200 Lift
- 83CFM@.100 Lift
- Ported Si-R ( P30 ) IM 63mm Throttle body
- B18b 95 intégra Intake cam B20b 97 JDM ex. cam
- AEM cams gears
- Stock valves and B18b springs (no B20B springs)
- Modified LS air box wit Stock filter (ran my old LSVTEC set up at 202Whp)
- Tri-Y headers, 15" of 2 1/2" exhaust line at headers and 3" balance
- 3" reson and 3" muffler No cat ( same than my old LSVTEC set up)
- P30 chiped wit Hondata S200 (basemap P-75)
- Fuel regulator seted up at 42psi IDL
Car ran already good. In my 95 Integra 2001 ITR tranny 1st gear is too strong dos'n hookup at anny RPM and i ad my best tires
Did'n push too much the motor in 2nd gear, but look like it will not hookup past 3500rpm
I did the set up to mak Torque and i wish 160 WFPT will comout of it
and B18 cams use to make little more HP than Torque, so Hoping a 170WHP
Lot of HP for stock camsHP = Torque X rpm / 5252
If i can get 150Fpt at 6000rpm
Y'm done Y should i make 160FPT. i doo beleve that the stroke will ad 15FPT from the stock B20 that wee ran at 130 so it make 145
ading the 2 pts of CR i doo beleve in 5FPT
and the Air Flow from the P8R head will make the rest
I'm y dreaming ?
Dyno on B18b cams: https://honda-tech.com/forums/showth...658830&page=10
Dyno on Crower 404: https://honda-tech.com/forums/showth...658830&page=19
http://www.technika-ind.com/dynamo2.htm
But also maybe try new place.
http://www.synoptic-tuning.com/
And wat ever the result of the place i will go to i'm going to
REDLINE performance try is dyno for free
i was thinking 403's or 404's would do AWSEOME on this motor. And with a head flowing like that you wont have kind of problems hitting well over 210hp i think once a set of the crowers go in
Awesome!
That's not too different than my nonVTEC 2.3 liter DOHC F23. It's sililar to your build.
2307cc
87mm bore
97mm stroke
11.7CR
stock H23A1 cams (.375" lift, 183˚ duration IN/EX)
DC header
2.25" crush-bent straight exhaust
165whp 169 torque.
I swapped to a 2.5" mandrel bent exhaust, refreshed the head and installed Crower's Stage 3 cams and made 200whp 183wtq. Cams and exhaust made the difference! If you don't get the power you want cams are the way to go. Good luck.
BTW, got any pictures of the build?
-P
2307cc
87mm bore
97mm stroke
11.7CR
DC header
165whp 169 torque.
-P
The valves cover to tune it
No. I just open Throttle side to 63mm and wit a flexible extension and a sanding weel, i try to make begening of each port in the plenium bigger than the exit ( funnel) and a little polish ended wit 320 grit
I was more reffering to the fitting job on the LS head.
Here is 2 P8R heads non vtec to compare the mid stud that you need to lift from nonvtec head to fit Vtec (Pr3-P30) IM
Bothom head is modified Bolt in the oil plug (wit helicoil)
Here is the water pass tapered and the Upper last IM stud that going to need welding on intake Manifold to drill the hole aligned wit the stud
Awesome!
2307cc
87mm bore
97mm stroke
11.7CR
DC header
165whp 169 torque.
-P
2307cc
87mm bore
97mm stroke
11.7CR
DC header
165whp 169 torque.
-P
Advertised Duration Duration @ .050" Gross Lift w/1.75
---- 234 / 236 ----------- 194 / 196 --------- 395 / 380
Stock HONDA H23 Prelude Si (1994)Gross Lift w/1.85
Int- 240 Exh-240
Int- 183 Exh-183
Int- 414 Lift
Exh-414
http://www.crower.com/cat/import/honda/cams/h23.shtml
