ITR 22mm sway bar fit gsr
As long as you use the right brackets (plus bushings) you can get any sway bar kit to fit.
The ITR uses thicker material at the rear subframe than the GSR so with a larger sway bar it often causes the brackets to rip off from the mount points.
-A
-A
Thanks you guys, you really helped me out. The only reason why Im asking this is because my current setup is JDM ITR LCA,sway bar, shocks&springs and on the side i have the stock gsr sway bar,LCA. I wanted to go Function&Form and also keep ITR sway bar but now i might just think about selling the ITR setup all together and upgrade the gsr sway bar. Off topic but any suggestions on what brand of sway bar?
LHC
Sep 3, 2003 04:01 AM
mamaboy
Oct 29, 2001 10:30 AM
