Apexi Exhaust Rattling?
Old Aug 28, 2002 | 07:57 PM
GumballNA's Avatar
Default Apexi Exhaust Rattling?
Hey peepz, i have a 97 honda civic DX 2dr 5spd. And i had bought and installed the Apexi World Sport Cat-back.. now ever since i bought the exhaust one i cant tell to much of a difference then i could with the intake. and 2nd when ever i hit 3000rpms it rattles and its coming directly from the muffler i think but im not sure.. im going to be testing it friday.. but still not sure and it annoys me... and i dunt know if im loosing power.. cuz honestly i cant tell what so ever.. and i know the exhaust isrunning thru there fine cuz i can smell it and feel it... so anybody please help?!
Old Aug 28, 2002 | 08:02 PM
CzanSOHC's Avatar
Default Re: Apexi Exhaust Rattling? (Type-X)
are all the hanger secured? everything tight?
Old Aug 28, 2002 | 08:07 PM
Mugen Hamster's Avatar
I used to have the N1 on my 2000 ex (before it was stolen) but mine used to rattle at lower rpms. there are 2 things you can do: check under the car, if the B-pipe on the exhaust has 2 hangers on it, try to switch to the opposite one that is on your car (from left to right, or right to left), I've read that people with 96-00 civics often are able to switch from left to right, and this gives the s-pipe a little more clearance. If you can't do this, you'll need to bend the exhaust hangers a little bit. You can either do this yourself, or take it to any reputable muffler shop around your area. should be around $20 or less for this. i know mine used to bang against my gas tank until about 3k rpms. i had to have the hangers bent; i didn't know about switching the sides at the time. then my car was stolen. anyway, i'm on my way to getting another n1! Hope this helps! peace out
Old Aug 29, 2002 | 03:56 AM
94CivicSi's Avatar
Default Re: Apexi Exhaust Rattling? (import_racer_7)
WS's rub the heat shield for the gas tank. They all seem to do it. You can wrap the section of the Z pipe that's rubbing with some header wrap, or put a large stainless band clamp around the sheild AND the Z pipe to keep them together, or ideally, do both. You'd think as many of these as they've sold, they'd have improved the design by now.
Old Aug 30, 2002 | 10:18 AM
rob_d16y8's Avatar
Default Re: Apexi Exhaust Rattling? (94CivicSi)
My WS rubs the gas tank too. I'm sure it's a easy fix if you bring it to a muffler shop. I did make some extra space by switching the rubber hangers but at low rpm's mine still sometimes rubs.
Rob
Old Aug 30, 2002 | 03:38 PM
GumballNA's Avatar
Default Re: Apexi Exhaust Rattling? (rob_d16y8)
well i figured out what is wrong its the heat shield from the header.. thats around the stock one... it stuck to the header itself.. from the new exhaust ...
bfong13
Aug 14, 2004 05:41 AM
XtremeSpeed
Jul 23, 2004 11:11 PM
EriK20
Jun 5, 2003 04:27 PM
drunkenalex
Jun 23, 2002 07:00 PM
silverEH2
Mar 14, 2002 09:25 AM
