intake manifold project
Old Oct 6, 2009 | 10:54 AM
russianvr4's Avatar
OG Fabricator
Default intake manifold project
this is for a 70 510 with an L20 turbo motor, it originally had ITB's and they were a pain in the *** to tune so im making a new intake with a single throttle body. ID 725cc injectors and most of the hardware is from RMR.
im off to put it all together now!
Old Oct 6, 2009 | 03:37 PM
russianvr4's Avatar
OG Fabricator
Default Re: intake manifold project
here is where im at so far
Old Oct 6, 2009 | 07:27 PM
Nick Z32's Avatar
careful tacking with the engine grounded...
Old Oct 6, 2009 | 07:28 PM
Wheels 2's Avatar
Looks good so far.Only if i had the time and skills.
Old Oct 6, 2009 | 09:46 PM
russianvr4's Avatar
OG Fabricator
the ecu is unplugged
Old Oct 9, 2009 | 07:37 AM
legendboy's Avatar
nice job on getting thoes pilot holes drilled on center
Old Oct 9, 2009 | 08:40 AM
russianvr4's Avatar
OG Fabricator
how it sits right now, having the flanges surfaced then either gonna polish it or anodize.
Old Oct 9, 2009 | 04:39 PM
Wheels 2's Avatar
Looks good.But i would have ground down the welds inside the intake.Before i welded it back up.
Old Oct 9, 2009 | 04:43 PM
lohatch's Avatar
fab work looks decent but i would have had bigger radiuses or velocity stacks on the ends of those runners.
Old Oct 9, 2009 | 10:57 PM
mavvrik's Avatar
That's deffinitly my next project. I've been dying to do this for months. Your welds aren't too bad either. Nice work
Old Oct 9, 2009 | 11:45 PM
russianvr4's Avatar
OG Fabricator
thanks guys, im learning as i go still. my biggest issue right now is keeping the weld clean and not dipping the tungsten into the puddle.
had to bust out a 1/8 tungsten for this baby because the 3/32 was starting to melt at 200 amps. and i only had a collet body not a gas lense so i'd have to keep the tungsten like 1mm off the puddle otherwise the irregularity of the gas flow would introduce contamination into the weld. being so close to the puddle, any slight movement of the arm would send the tungsten into it messing it up. was definately a trial and i learned a lot.
hoping to have some finished/anodized pics for you guys next week.
egycasper
Welding / Fabrication
Dec 22, 2017 11:35 AM
weiRtech
21
Oct 14, 2009 09:47 PM
prostreetonline
Nov 26, 2008 07:08 AM
Honda_Fanatic
Oct 25, 2007 10:12 AM
