1.9L ITR motor?
Old Oct 6, 2009 | 08:50 AM
Fresh'86's Avatar
Default 1.9L ITR motor?
Sorry if this has been asked before, I tried to search but got no results. I was wondering if I can bore the ITR block from 81mm to 84.5mm or would that be unsafe and would require sleeving?
Thanks.
Old Oct 6, 2009 | 08:51 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: 1.9L ITR motor?
Sleeving is required.
Old Oct 6, 2009 | 08:53 AM
raiden571's Avatar
or you can put in ls crank and rods, bore to 82mm and it should yield a 1.9
Old Oct 6, 2009 | 06:41 PM
Fresh'86's Avatar
ah ok, thanks a lot guys!
Old Oct 6, 2009 | 07:11 PM
night's Avatar
debatable to me if you can call it an itr after swapping the crank. but it would be cheaper.
Old Oct 6, 2009 | 08:34 PM
DDTECH's Avatar
Max on stock sleeves is 83, sleeving will be required.
Old Oct 6, 2009 | 08:50 PM
ExospeedAMcrx's Avatar
Really? I've never seen anyone try that yet.
Old Oct 6, 2009 | 08:54 PM
TheShodan's Avatar
Moderator
I agree. I've only gone as far as 82mm myself
Old Oct 6, 2009 | 09:00 PM
DDTECH's Avatar
A few people have done it.. you can use a stock HG to 82mm, at 83.. GE sells a gasket for it. But there's been a few builds for 83mm on stock sleeves.
Strictly drag racing tho..your pushing the limits at 83..
Old Oct 7, 2009 | 01:05 AM
Not knockin on you, just my personal opinion ok.
83mm sleeved is common, but personally I would never tell someone to do an 83mm unsleeved or even an 87mm Sleeved B-series, unless the person knows what theyre doing and the consquences of that setup. 83mm on a stock sleeve, really what for? Might as well just get a B20 at 84mm and build that up.
Old Oct 7, 2009 | 06:28 AM
Fresh'86's Avatar
^Yeah I would rather just swap the crank into a B20 block rather than pushing it to 83 and preparing for it to eventually take a poop.
Old Oct 7, 2009 | 08:27 AM
DDTECH's Avatar
oh me personally would never do that, the best i've seen w/o any worries is 82mm on stock sleeves
like i said.. i wouldn't do it.
Old Oct 8, 2009 | 08:54 AM
PyroProblem's Avatar
83mm on stock sleeves huh? Any links to these builds?
Old Oct 8, 2009 | 11:04 PM
drag_killer's Avatar
Lot of vtec enthusiasts in Malaysia use 83mm piston on b18c stock sleeves, huhu hard to find GE Sleeves..how much for GE sleeves nowadays?
Old Oct 9, 2009 | 04:01 PM
Hmmm....I got an extra ls block lying around...Might have to experiment a little with this idea.....
Trust-Me
12
Jan 11, 2010 02:55 PM
tofu-eg
Jun 1, 2008 03:09 PM
4dooritr
24
Apr 30, 2008 05:09 PM
j87w
Feb 7, 2005 06:02 AM
