are civic si shocks the same as civic cx shock asfar as fit goes
so i'm trying to figure out if civic si shock are the same as the civic cx shocks because i have a b6 in my cx and i am about to buy bilstien sport shocks and i want to know if they are the same because i figure if so i will go with the si shocks to suport the weight of my b16 if it weighs anymore ... thank you for the help on this.
also is there any other front lower control arms that will support sway bars other than the stock si lca's ?
As far as I know all the shocks from 92+ are the same on all civic's and 94+ integra's and should interchange. I'm about 80% sure the samething applys on the lca's as well.
Struts are the same. If you use the SI 26mm sway bar, you'll need the lca and forks as well. They work well, but you'll need to balance out the rear with something beefy, like the ITR sway bar. It will help reduce understeer.
