PA: Massive cleanup sale 60+ items
D15 CRX Alternator $10
1991 Civic DX engine/trans needs clutch $100
90-93 Integra Brake master cylinder $10
1999 Integra LS cylinder head $75
OBD2B to OBD1 conversion harness $85
1994 Civic front knuckles w/ crossdrilled rotors, one missing UCA $20
Misc. B Series timing covers, PM for specific ones $10 each
95 Honda Civic rad fan $15
95 Honda Civic D series rad hoses $10
95 Honda Civic D series shift rod $10
1991 Civic DX hatch shift linkage $15
CRX DX axles $20
JDM H22a Cap and wires $15
1995 Honda Civic D series front axles $15
H22a auto axles $15
OBD2 LS intake manifolds x 2 $20 each
B series plug cover $5
JDM H22a fuel rail $5
OBD1 B series injectors $40
OBD2 P30 fuel rail $10
B series alternator brackets $5
B series starter $15
B18A crank pulley $15
B18A valve cover $25
JDM B16A DA6 Power steering pump w bracket and bolts $20
JDM B16A DA6 AC compressor w bracket and bolts $20
1991 Civic DX hatch axles $20
95 Honda Civic D series power steering pump $10
D16Z6 water pump $15
B18B water pumps x 2 $15 each
95 Civic D series rad hoses $10
93 Civic D series pass side torque mount bracket $5
94 Honda Civic power steering press. hose $5
94 Honda Civic 4 door taillights $20
94 Honda civic 4 door pass headlight and orange corner $10
91 Civic D15B2 longblock needs rings $25
93 Civic Si washer bottle $5
B series block/trans braces, flywheel cover and all OEM mounting hardware $25
DC2 Integra SIR-G rear control arms $10
95 Honda civic auto d series starter $10
PM5 ECU $10
B series Vtec water pumps x 2 $25 each
B18B cams $15
Prelude P14 H23a manual ecu $20
B series Vtec timing belt $10
B series flywheel $20
H23A header $30
CRX DX axles $20
H22a auto axles $15
PM5 ECU $10
B18B cams $15
H23A header $30
