Widest, Street use, Summer Tires for 15*7 Lowered Interga
Old Oct 5, 2009 | 06:59 AM
schumi's Avatar
Default Widest, Street use, Summer Tires for 15*7 Lowered Interga
Its for my daily driver, mainly for Dry climate ...no snow issues here!!!!! Not too concerned about performance either....Just needs some decet grip.....Car is lowered on Ground contriols/Koni.
I always liked Azenis but I think its an over kill for my 80 mile commute. Its not cheap either.
What are the suggestions on brand and tire size? thx
Old Oct 5, 2009 | 04:58 PM
alphalanos's Avatar
Default Re: Widest, Street use, Summer Tires for 15*7 Lowered Interga
width isnt as important as compound. Some good summer tires in 195 and/or 205 are: Bridgeston RE-11, Kumho Ectsa XS, Yokohama S Drive, Michelin PE2, Hankook Ventus RS-2, Dunlop Direzza Star Spec. Im using S Drives right now and theyre not super sticky but they are a good mix of treadwear and dry grip, and quite good in the wet.
-btw Azenis are pretty darn cheap for what you get, they are getting old though and are behind some of these tires.
Old Oct 5, 2009 | 08:00 PM
schumi's Avatar
What's the widest tire size for a 15*7 wheel ? I think the offset is 40...
Old Oct 6, 2009 | 12:04 PM
nsxtasy's Avatar
H-T Order of Merit
The best size is either 195/55-15 or 205/50-15; either one can be mounted on 15x7 and will work fine. Width is not important. Choose a tire based on your priorities. The tires mentioned by alphalanos are good recommendations. The Yokohama S.drive is probably the best for your usage, since it is reasonably priced and will last longer than those supersticky tires (20-40K miles, vs 15-20K). For the S.drive, I recommend the 195/55 rather than the 205/50 because the 195/55 is cheaper.
Old Oct 6, 2009 | 08:00 PM
schumi's Avatar
Reason why I wanted a wider foot print os for looks....I persoanlly prefer the wheel/tire combination where the wheels wells are covered/ looks full.
Ex. I had 205 40 16 Azenis on 16" wheels and 205 50 15 Azenis on 15" wheels. With those 16's the integra was looking very "Skinny" where as the lowered looks on the 205 50 15's were greta!!!!
Old Oct 6, 2009 | 10:18 PM
schumi's Avatar
http://www.caranddriver.com/reviews/...mparison_tests
Very good comparison
Benchmark: Michelin Pilot Sport PS2
Ninth: Ling Long L688
Eighth: Nitto Invo
Seventh: Falken Azenis RT-615
Sixth: Yokohama S.Drive
Fifth: BFGoodrich g-Force T/A KDW
Fourth: Bridgestone Potenza RE760 Sport
Third: Kumho Ecsta XS
Second: Hankook Ventus V12 Evo
First: Dunlop Direzza
Old Oct 7, 2009 | 08:38 AM
konad's Avatar
Keep in mind a lot of tires can be made to fit... It just depends on what your willing to do, roll/pull etc.
Old Oct 7, 2009 | 04:46 PM
schumi's Avatar
Not planning to roll the fenders etc...I think I had done that when I sed to Auto-x
Old Oct 8, 2009 | 08:03 AM
Tokyosmash!'s Avatar
Tickle-shits
Community Builder
Community Influencer
You can easily fit a 225 on a 7
Old Oct 8, 2009 | 10:03 AM
schumi's Avatar
some one is selling a set of 215x40R17 Falkan RT-615's mounted on 17x7 Konig Helium's in 4x100mm.
This should fit integra without any rubbing issues?
Old Oct 8, 2009 | 11:25 AM
rick_rabies's Avatar
I'm not Rick!
can you fit a tire 225 on a 6.5 inch wide rim?
Old Oct 9, 2009 | 09:15 AM
schumi's Avatar
Folks, what do you think about 215x40R17 Falkan RT-615's mounted on 17x7 Konig Helium's in 4x100mm.
Old Oct 9, 2009 | 11:48 AM
TunerN00b's Avatar
Without listing the offset, how can anyone be expected to answer that?
Old Oct 9, 2009 | 02:01 PM
racebum's Avatar
Eighth: Nitto Invo
this test made me LOL some. i really don't see how the 615 is ranked behind the KDW, s drive or 760. it sure isn't for performance. i can understand the rest though. imo they put too much on "ride" and wet performance. i really don't think anyone buying the 615 or xs is considering this tire for deep water performance.
Old Oct 9, 2009 | 02:02 PM
racebum's Avatar
i guess we're suppose to memorize the offset LOL, i think it's 40 or 42 but someone should look it up if they want to know. it's better than expecting us to remember it
Old Oct 9, 2009 | 09:31 PM
konad's Avatar
What.
Old Oct 11, 2009 | 03:06 PM
Sickteg24's Avatar
I have 225/45/15 Toyo R1R's on my 7in wide RPF1's with no rubbage.
Old Oct 12, 2009 | 04:10 PM
schumi's Avatar
offset is +40...come on guys, if you are hanging out in this forum, you are supposed to know the offset for Kong Heliums....J/K
Old Oct 13, 2009 | 11:54 AM
nsxtasy's Avatar
H-T Order of Merit
Not necessarily. It might rub, depending on actual size (not just width), offset, etc.
If you don't want rubbing issues, stick with 205/40-17.
That test was really nonsense, mixing some tires designed for dry traction, other tires that are designed for treadlife as well as wet and dry traction, etc. To claim that those tires are best in exactly that order (when different people's different priorities may say otherwise), and to ignore all the many tires that weren't included in that test, are ridiculous.
Old Oct 13, 2009 | 05:02 PM
jonnyt1130's Avatar
yes you can..i had the bfg 225/50/15 drag radials on my 6.5in stock 05 ex rims. fit and looks nice and didnt even rub on my crx!
Old Oct 13, 2009 | 10:12 PM
nsxtasy's Avatar
H-T Order of Merit
Originally Posted by jonnyt1130
yes you can..
You can't answer the question without knowing exactly what tire size is being used (which might not be the 225/50-15 you mention). There are lots of instances in which a tire of a certain treadwidth can be used on a certain width of wheel, but a different tire size with the same treadwidth can't be used on the same width wheel. For example, most 205/50-15 tires are approved for mounting on wheels 5.5-7.5 inches wide, whereas most 205/45-16 tires can be mounted on wheels 6.5-7.5 inches wide, and most 205/40-17 tires can go on wheels 7.0-8.0 inches wide. As you can see, it's not the same for all tires with the same treadwidth.
Old Oct 13, 2009 | 10:34 PM
racebum's Avatar
that's what i'm saying, i mean ****, throw in a hankook icebear for good measure.
Jswike
Jan 14, 2013 04:15 AM
John Piche
Oct 22, 2012 09:11 PM
Olsen
May 4, 2011 06:17 AM
hanskies
Jul 28, 2006 08:44 AM
AccordCD5
Nov 8, 2004 11:32 AM
