'99 Accord EX 4 cyl. temp gauge going to cold then back to operating?
The temp gauge in my '99 Accord EX sedan in 4 cyl. 5-speed has a issue with the tempature gauge. Eveny once in awhile after I have been on the road or warm stated it the gauage withh drop to cold. Two second latter it is reading normal operting temp again?? Is this a sensor, or wiring issue likely. Or something worse like bubbles in the system?
Check connections at the temperature sending unit on the cylinder head. Probably not an issue with the actual cooling system. Likely just an electrical problem.
JackBlack2233
Nov 23, 2016 10:14 AM
Agent Daimon
Nov 29, 2015 02:25 AM
professorman
Aug 16, 2014 06:33 PM
