Wire tuck
If you can even find a shop that will do it, it will be crazy expensive. It's not hard work, just time consuming.. and shops usually charge by the hour, so that's bad for you.
You can try getting a harness from chasebays. That's pretty much the hardest part of doing a tuck.
why the hell would you want a shop doing this ?
If you have an electrical problem down the road, how are you going to know where it is ? At least doing it yourself, you always know where you ran the wires and where you can check. Do it yourself, it is time consuming, and most shops would not even do this kind of work.
votoms888
May 10, 2007 06:13 PM
