Auto off lights
How to install it? I believe the Viper alarm I installed has the option to do this but was something you had to program after the fact. It has a timer for the other lights (corners and interior) so I'm sure the same could be done with the headlights. That is assuming you arm/disarm when you want them to turn off and start the timer.
You might look into whether the CL of the same year range had auto-off headlights or not. If it did, you might be able to just change your relay out for the CL one. I wouldn't know for sure without looking at the electrical schematics.
