Freeing a stuck bolt on the auto tranny for drain and refill.
Old Oct 4, 2009 | 02:48 PM
ferio252's Avatar
Default Freeing a stuck bolt on the auto tranny for drain and refill.
So the bolt that I need to loosen is very hard to take out, Tried manhandling it with extra leverage, torching it to expand the threads and soaking it with WD40. no dice. The bolt is recessed into the housing. Any advice ???
Thank you HT. in advance.
Old Oct 4, 2009 | 04:50 PM
miguel329's Avatar
Default Re: Freeing a stuck bolt on the auto tranny for drain and refill.
take it to a shop if its that bad.. doubt the charge much to loosen
Old Oct 4, 2009 | 04:54 PM
acake em1's Avatar
Colonel Cake Mix
there is a product they make that you spray on kinda like the WD40 to loosen bolts, but i cant remember for the life of me what its called, hopefully someone will see this and remember
Old Oct 4, 2009 | 05:05 PM
Black Diamond's Avatar
PB BLASTER..dont know where the hell to find it,,,i would Google it
-NICK
Old Oct 4, 2009 | 05:07 PM
acake em1's Avatar
Colonel Cake Mix
there it is OP
Old Oct 5, 2009 | 01:46 PM
ferio252's Avatar
Thank you guys. I will try this out.
Old Oct 5, 2009 | 02:08 PM
civlxbro's Avatar
Anyone have a write up on Tranny Fluid change? Thats next on my list of things to do!
Thanks!
Old Oct 5, 2009 | 08:50 PM
Kista20's Avatar
advance, napa, tractor supply, or just about any other parts store will have the pb blaster. Make sure you drive the car to get the tranny really good and hot it will make that plug easier to come out. I screwed up once and I wanted to change the oil pan gasket and didn't let the oil warm up enough so needless to say the drain plug rounded off on me and I had to get a craftsman bolt out set to remove it.
Old Oct 6, 2009 | 08:18 AM
jooky5's Avatar
pb blaster is good
liquid wrench is good too
WD 40 is useless, Doesn't do any one job well. doesn't penetrate, doesn't lubricate, doesn't protect. Good marketing though.
GSRWSU
Transmission & Drivetrain
Jun 25, 2009 03:26 PM
C1power
Jan 7, 2006 03:27 PM
Mackenzie
12
Oct 30, 2004 07:49 PM
Batoutahell
Oct 17, 2002 06:36 PM
confucius
May 15, 2002 10:15 PM
