zc crankshaft
Old Oct 4, 2009 | 11:28 AM
bokamper17's Avatar
Default zc crankshaft
ive heard that you can use other cranks in these but i wasnt sure. i have a dohc zc. if you know let me know. please
Old Oct 4, 2009 | 03:23 PM
Bunger's Avatar
Default Re: zc crankshaft
Should be able to us a a6 or z6 crank, I'd shy away from the y8, oiling issues.
Old Oct 5, 2009 | 06:12 AM
jlicrx's Avatar
any D16 crankshaft will work, however, DOHC ZC, SOHC ZC, D16A1 and D16A6 crankshafts came with 2 different diameter front snouts (where the pulley goes on) - some were 22mm diameter and some were 24mm diameter - you need to get the crankshaft that has the same diameter front snout as the one you are replacing - the crankshaft gear for the timing belt also fits on the front snout and has to match the diameter of the crankshaft - the DOHC ZC gear has 17 teeth and the DOHC ZC is the only one that works - DOHC ZC gears for the 22mm crankshaft are really hard to find
Old Oct 5, 2009 | 06:20 AM
BiGZ's Avatar
^Listen to this guy...
Old Oct 5, 2009 | 07:22 AM
Bunger's Avatar
A d17 crank fits also, just needs a few extra bits to make the setup work.
tyler100
Nov 3, 2008 08:21 AM
9db85
Apr 2, 2007 11:39 AM
CRX_Phantom1
Nov 24, 2005 05:10 AM
DaMmniTz
Nov 17, 2004 02:55 PM
