high compression gsr questions
i have a gsr block bored .020 over, and im new to the all motor building game. i have a ls crank and i was wondering if that would be good to run with the gsr block. i was also wondering what rod piston combo would give me the best results with the ls crank (would ls rods be good for the build or should i go with eagle?) As well as if a b16, gsr, or ls tranny would be best for the build
thanks guys for all your help in advance,
Ryan
Ryan
The LS crank will work fine in the GSR block, but you will have to use Ls rods with that crank because Gsr rods are longer. You can use any B series piston to go with the rods, the stroke and bore should give you little more displacement. I would go with Gsr tranny but if your looking for a shorter gear ratio the B16 tranny is what you want.
Ryan
Ryan
Well on the tranny advice u can get a b16 tranny for shorter gears but it depends on your driving n what u are using the car for I got a lsv an I love my gsr trans I had b16 but wasn't for me so good luck with build......
electric_rex
Dec 5, 2004 02:57 PM
