1992 civic si turbo k20a2 super cleannnnnnn
Here is my 1992 civic si clean title that i am selling. car has a k20a2 turbo in it. the car is not tuned right now but will be tuned on e85 and should make between 475hp to 505hp on 16-20 psi. Will be tuned by Mikey at profunction. the car will not come with the fuel system and fuel cell that is in the pictures will come with stock tank and walbro 255. i am asking 10500obo. i did run the car at 10 pounds of boost with base map at track on slicks and did 1.8 60ft. r/t .755 .1/4 mile 11.7. on 16psi should break into 10's no problem.
Engine
-k20a2 type s swap (with fresh rebuild with pistons and rings all new gaskets done at 25xxx miles)
-stock k20a2 6 speed tranny with all new syncros
-stage 4 competition 4 puck unsprung clutch (550hp)
-welbro 255 intank fuel pump
-3 inch piping
-gready bov
-percision intercooler (550hp)
-fuel pressure regulator
-rev hard manifold
-t4 t04b-2 big wheel 70 a/r 1.15 a/r good for (650 hp)
-rc 1000cc injectors
-karcepts k20 mounts into eg
-hybrid k20 axles into eg
-hassport k20 into eg wire harness
-stainless steel clutch line
-earls return turbo oil fittings
-blox sandwitch plate
-k-pro ecu
-fluidyne radiator dual core radiator with slim fan
-taylor battery relocation kit
interior
-nrg steering wheel
-nrg quick release hub
-sparco red and black both racing seats with sparco harness
-full cage good for 9's 10 point (even goes threw dash)
-stock dash fully striped in side
suspension and wheels
-ksport full suspension
-skunk 2 front upper camber
-skunk 2 rear lower control arms
-nrg front and back strut bars
-itr 5 lug whole trailing arms and spindles
-all brand new calipers
-itr gun metal rims with bf good ridge tires brand new
exterior
-the car is super clean was painted about 2 months ago it is 2000 si blue.
-it was painted about 2 months ago it is 2000 si blue.
-the roof is black
-the body is all oem
- no rust at all
-all quater panels are new(i got pics when being welded and putting together the whole body
-seibon hood carbon fiber hoods with black sides
-vis carbon fiber trunk
-amber corners
-carbon fiber duckbill
-10k hids
http://i480.photobucket.com/albums/r.../IMG003991.jpg
http://i480.photobucket.com/albums/r.../IMG003911.jpg
http://i480.photobucket.com/albums/r...0929-17571.jpg
http://i480.photobucket.com/albums/r...0929-17561.jpg
http://i480.photobucket.com/albums/r...0929-17551.jpg
http://i480.photobucket.com/albums/r...0929-17541.jpg
http://i480.photobucket.com/albums/r.../cid955131.jpg
http://i480.photobucket.com/albums/r.../cid951501.jpg
http://i480.photobucket.com/albums/r...k/brian006.jpg
if interested or any questions call or text 1 708 663 6872 Sylwester or email
only interested in trades for mitsubishi evo crashed ,blown motor body damage ect.
other wise CASH ONLY this car is sick.
Engine
-3 inch piping
-gready bov
-rev hard manifold
-k-pro ecu
interior
-nrg steering wheel
exterior
-the roof is black
- no rust at all
-amber corners
-10k hids
