Ive got a coolant leak from behind the timing cover
Old Oct 3, 2009 | 05:59 PM
TravisB16a's Avatar
Default Ive got a coolant leak from behind the timing cover
Ive got a coolant leak from behind the timing cover , what could be leaking from back there ?
Old Oct 3, 2009 | 06:00 PM
TravisB16a's Avatar
Default Re: Ive got a coolant leak from behind the timing cover
im sorry its a d15
Old Oct 3, 2009 | 06:06 PM
Simkin314's Avatar
It could be the water pump gasket/water pump or head gasket (but head gasket generally has other symptoms alongside).
Old Oct 3, 2009 | 06:51 PM
TravisB16a's Avatar
I hope its not the head gasket . Its not blowing white smoke or over heating or anything like that . now the only problem i am having is getting the stupid pully bolt off to I can pull the rest of the timing cover and get at the water pump.
Old Oct 3, 2009 | 07:39 PM
Crazy4Honda's Avatar
from where on the cover is it leaking?
Old Oct 4, 2009 | 06:27 AM
TravisB16a's Avatar
it was coming from the back side of the cover and now it is coming right out the bottom
Old Oct 4, 2009 | 07:59 PM
mouab18c1's Avatar
could be a bad o ring on the thermostat pipe or either waterpump..does it leak alot or just a little
Old Oct 4, 2009 | 11:18 PM
dcvt16's Avatar
check the water pump weep hole. once the weep starts leaking its time to replace the pump.
check it asap, because if thats what it is, the next thing thats going to happen is the pump is gonna freeze up and take the timing belt with it.
Old Oct 5, 2009 | 12:00 PM
srmofo's Avatar
water pump weep hole, replace asap
Old Oct 5, 2009 | 02:23 PM
ironcheftony's Avatar
Water pump
cstap
Oct 10, 2013 06:34 AM
tony_yang
Honda Civic (2006 - 2015)
Jan 28, 2011 03:49 PM
AnotherEJ
Jan 17, 2009 06:33 PM
Scott (T.O.A)
Aug 5, 2007 06:29 AM
Mrob91GS
Mar 26, 2005 08:25 AM
