FS: 94 dx coupe shell Gsr head Gsr Shortblock Ls hydro trans WSII exhaust
*I have a gsr head for sale that was cleaned up at Back's here in Lexington. New at time of build (7k miles ago) itr valves, valve seals, valve guides, 3-angle valve job and milled. Includes but not pictured valve cover, obd2 dist with passwordjdm jumper, complete intake manifold, cams and gears. Ready to bolt on and run just need to set valve lash. I would like $550 OBO.
*Ls Transmission hydro. I took it apart and inspected bearings and synchros, both checked out fine shifts smooth and no grinds or gear pop out. While I was in it I replaced the input shaft seal and both axle seals. $450 OBO no picture still in car
*Exedy lightweight flywheel and clutch kit b-series. Has maybe 15k miles on it. $100 OBO
*Next I have gsr shortblock that was rebuilt at same time as head 7k miles ago. It had at new at time of rebuild all from Courtesy Acura p73 itr pistons, rings, main and rod bearings, itr obd2 oil pump, water pump, seals and gaskets. $650 OBO (ARP headstuds not included)
*Apex'i world sport II exhaust for 92-95 civic coupe. $200 OBO
*94 Civic Dx shell 205k miles clean title it has a small spot of rust on driver's rear quarter panel at bottom not very visible. Interior is pretty clean other then driver's seat has normal bolster hole in it. Comes with suspension techniques sway bars (un-installed) front and rear, gsr fat 5 wheels, decent falken ziex tires, pioneer headunit, polk front speakers and 12" sub with amp also wired for xm radio just need subscription. Has b-series stock mounts and hasport bseries shift linkages - ready for your swap!
$1200 OBO
$1200 OBO
LightningTeg
Aug 29, 2016 06:30 AM
LightningTeg
Jun 12, 2015 08:09 PM
2.2_coupe
Southeast (Sales)
Oct 11, 2009 12:53 PM
b18cx
Texas -OK -LA (Sales)
Apr 15, 2008 10:17 AM
GsrBrideteg
Feb 17, 2004 09:39 PM
