Skunk2 Drag launch coilovers
Has anyone used the Skunk2 Drag launch coilovers? I currently have eibach drag springs and cant use them because I cant get my slicks on. Or is there anyway to raise my suspension with the eibach springs?
thanks
thanks
As good as any other setup, the best coilovers in the world wont make a difference if you have crappy tires, bad alignment, no corner balancing and/or cant drive etc etc
My friend cut 1.60-1.65 with them all day open diff.......
so what your saying is I can buy ebay coilovers and they are as good as the skunk2. my question is about coilovers not tires, alignment, corner balancing and the way I drive. please read whole posting before comenting
Well people's 60 ft times are pretty much irrelevant the entire car is what gets you a 60 ft not the coilovers. I've seen people cut 1.6 60 fts with ebay coilovers.
OP they are just stiff springs on adjustable perches, they all pretty much do the same thing as every other drag launch springs, if your looking for a complete setup the best value seems to be the Blox Coilovers, I seen them for like $650 and they are just copies of the OMNI's from what I hear, I will be giving them a try as well this year.
What shocks are you running now?
I have the s2 drag launch. Just got done cutting 1.62-1.63 60s on some 8 year old 24.5s...
they are back breaking on the street sometimes tho...
i run skunk2 drag launch on mines.i pull 1.71 60 foot and ran a 10.60 at 142 mph.stock chassis,full interior,no cage, but with a traction bar.hopefully that helps you.im on ebay omni knock offs front full struts and real omni rear full struts.both on drag launch.front and rears.
The drag launch springs should help you at least a little bit. I've cut 1.70's 60ft on completely stock suspension in my integra with m/t 24.5's. I used to have some neuspeed springs on it but i had to take them off so i could get my slicks on too..lol
