94-01 Integra clock cover, need to remove clock to put in?
Here is the clock cover
Here is a picture of the integra clock
Can you put the cover over/on top the clock or are you supposed to remove the actual clock unit to put the cover on?
You have to remove it. I think the point is when the clock is removed, you can block off the ugly hole. Not to just cover the clock.
you need to remove the clock. to remove it, carefully use a flat head screw driver (with electrical tape on the end) to pry it out on one side. Then you came remove it by hand.
Mine has been in and out a few times, so I can kinda squeeze it to one side to pull it out, if that makes any sense.
big_poppa492004
Aug 30, 2008 12:30 PM
