Fuel Pressure too high? 44-45psi
Old Oct 2, 2009 | 06:04 PM
jdmek9imagex's Avatar
Default Fuel Pressure too high? 44-45psi
Hey, i have a pressure gauge mounted to the fuel filter. Notice that the psi is at 44-45 psi. Is that normal? have an aftermarket fuel rail, aem pressure regulator, aem fuel filter.
thanks
help would be greatly appreciated
Old Oct 2, 2009 | 06:32 PM
Default Re: Fuel Pressure too high? 44-45psi
bump anyone know?
Old Oct 2, 2009 | 09:43 PM
thumper64's Avatar
I thought it was supposed to be like 50 something. I'd look up what Honda recommends and adjust it accordingly. I found it in like 5 minutes one time, you can do the same.
Old Oct 2, 2009 | 09:44 PM
B16Drag's Avatar
44-45psi is normal
Old Oct 2, 2009 | 09:55 PM
Ruben19's Avatar
what motor ?
any mods?
motor tuned?
oem b series with vacuum line on should be 37-39psi
Old Oct 3, 2009 | 11:29 AM
Originally Posted by Ruben19
what motor ?
any mods?
motor tuned?
I did some searches and they said its normal to be around 39-40psi.
B18C2 gsr obdII, itr cams, stunk2 cam gears, itr headers, aem fuel filter, aftermarket fuel rail (blox i think), aem fuel pressure regulator, stunk2 manifold, aem short ram intake. Stock fuel pump.
I have code p0505 idel air control and P1456 evap emission leak thats why im asking. I smell gas sometime near the rear driver side, near the gas filler side
Old Oct 3, 2009 | 07:45 PM
bump. with all the mods, would it cause the pressure to be between 44-45psi?
Old Oct 3, 2009 | 08:15 PM
B16Drag's Avatar
you can just use the regulator to adjust it to whatever you want. If its stock motor, I'd suggest you leave it where it should be stock around 42psi or so. If its not, then dont mess with it unless you have an wideband or know what you are doing.
The aem fuel rail, regulator, and filter wont change a damn thing... The stock ones are just as good.
envision
Aug 26, 2015 02:00 PM
iwannarace
Jun 5, 2011 01:34 PM
chinners10
Jan 28, 2004 05:52 PM
allmotorjay
Jun 27, 2003 04:28 PM
