Heating Problem
Old Oct 2, 2009 | 01:13 PM
burntkookie's Avatar
Default Heating Problem
Car:95 civic ex 1.6l
Today my car started to over heat but i caught it at the right time to cool down the engine. I was driving around 90mph down the freeway and went to a complete stop at a exit... Can someone tell me whats going on with my damn car? Could it be my headgasket, leak at the radiator?
And also can someone tell me whats the normal idle rpm when completely stop and in drive, because my idle rpm looks around 400rpm, normal or not?
Old Oct 2, 2009 | 01:30 PM
ferio252's Avatar
Default Re: Heating Problem
For my 99n Civic Sedan D16y7, my idle is supposed to be 600-700 rpm. As for your car overheating it could a number of things. Any more information about the problem? Bump for someone with more expertise.
Old Oct 2, 2009 | 01:32 PM
The overheating problem happens only if i go past 80mph, and come to a complete stop after taking an exit, also it happens only during the day.
Old Oct 2, 2009 | 03:34 PM
gwl's Avatar
gwl
I had a similar problem. When I started to slowdown on the freeway, my temp started to rise toward the high side. It was a faulty thermostat.
Old Oct 2, 2009 | 06:07 PM
Group Tenacity's Avatar
could be a number of things, thermostat (said above), thermostat switch, water pump going out, or head gasket (<- if you see coolant bubbling in your over flow tank this is the problem)
Old Oct 3, 2009 | 10:22 AM
i replaced the thermostat,water pump, thermostat switch, and there isnt any bubbles in the over flow tank..Any other ideas?
Old Oct 3, 2009 | 10:32 AM
Former User's Avatar
Are you losing coolant? Any white smoke in the exhaust? If not, bleed the cooling system as described below. It the engine still overheats, consider replacing the radiator.
Bleeding the cooling system:
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push the dash heater lever/**** to MAX heat.
3) Follow the directions in the diagram below (hint: the bleed bolt is located where the upper radiator hose connects to the engine):
Old Oct 3, 2009 | 11:12 AM
Jimster480's Avatar
Could be a faulty thermostat
Old Oct 3, 2009 | 08:21 PM
i bled the whole system already, for some weird reason its still over heating...Any other sugesstions?? The thermostat is about 3 months old only, do i dont think its that.
Old Oct 5, 2009 | 02:26 PM
Jimster480's Avatar
Is your radatior fan turning on all the time?
Old Oct 5, 2009 | 03:37 PM
yes it turns on all the time...But idk why its still overheating...
Old Oct 5, 2009 | 04:45 PM
Jimster480's Avatar
Maybe your radiator itself is bad. Or your water pump is going.
Old Oct 6, 2009 | 05:08 AM
Is there a way to hardwire the fan so it can keep running when i start my engine? Bad or good idea?
Old Oct 6, 2009 | 07:02 AM
Jimster480's Avatar
thats what I did on my car. you just unplug the wire from the sensor and put a wire in between the 2
Old Oct 7, 2009 | 08:11 PM
Alright so idk what the hell is goin on with my car anymore...The fan wont even turn on... Im just thinking of getting a new radiator and fan.
Any pros and cons for aluminum radiators than stock radiators??
I need a quick response so i can order that part tonight.
Old Oct 7, 2009 | 08:46 PM
Bleed it again (exactly as I posted) before you buy anything.
davey5300
Feb 25, 2009 01:19 PM
hahaha38
Honda Civic (2001 - 2005)
Feb 10, 2008 01:27 AM
Missouri_Civ
Jul 9, 2007 04:14 PM
swcrazy
Feb 8, 2007 08:24 AM
