traction in a CRX with a GSR motor?
Hello!
I'm probably gonna buy a crx 88-91 and swap the motor with a GSR. Maybe i will put a type R tranny with the LSD. How much the car is gonna weight? And with about 200hp, will i get any traction in such a lightweight car??
thank you
thank you
Guest
Posts: n/a
mmm, yeah, but im asking if i will get traction in a FWD lightweight car with 200hp?
you obviously don't know ****, so listen to what people have to say.
the hydro conversion looks like a biatch....mackymcg did a write up on it.... https://honda-tech.com/zerothread?id=220712
would an aftermarket front crossmember w/ adjustable radius rods paired w/ ES bushings help?
the problem you run into with 200whp and a ~2000lb car is that the front end just doesn't weigh enough to keep the front tires from not spinning.
yea i have trouble keeping the tires planted in 1st on my stock b18c and im probably only putting down around 150whp...the reason for that is really cheap tires on my stoch 13" 175/70 tires dont cut it man...
oh yea and you may wanna reconsider the whole hydro tranny...just get a cable with a stock LSD...your gonna have fitment issues with the hydro due to its size and your small engine bay
if you're a good driver with decent tires you'll know where the breaking point is.
I suggest you get a custom front crossmember (Z10) since you'll want one for engine clearance anyway, that will help traction alot.
mmm, yeah, don't act like an *** when people are helping you newbie.
the only way to really solve your tracktion problems is to find a really stiff rear springs and try nitto nt555r's that combo should be the best for street driving
Do you not realize that the weight distribution is severely biased towards the front in the CRX. The center of mass front to rear is just behind the front edge of the doors. The majority of that 2000 pounds is on the front wheels.
but i guess more could be due to weight transfer to the back. all i know is tbone is running the new bfg drag radials, has some pretty stiff springs in the rear and he still spun in 1st and 2nd with throttle modulation....
i have no problem with my gsr swap i also i have a 4 puck act racing clutch i almost drive it everyday just be easy on it.. i can spin it all the way to end of 3rd if i wanted to, but why, but i have
... hydro tranny fits fine!!! you just need to make a custom mount... i'm riding on 15's with avs, but i don't think they sell these anymore.. and 200 whp or 150 it doesn't really matter, just feather the clutch on 1st and 2nd...
edit: wuhungsi since you live in sac have you ran your car yet?? times mph tires
[Modified by XtraFastCRX, 9:16 AM 8/30/2002]
... hydro tranny fits fine!!! you just need to make a custom mount... i'm riding on 15's with avs, but i don't think they sell these anymore.. and 200 whp or 150 it doesn't really matter, just feather the clutch on 1st and 2nd...edit: wuhungsi since you live in sac have you ran your car yet?? times mph tires
"edit: wuhungsi since you live in sac have you ran your car yet?? times mph tires "
nope!...just got the car BARed and insured lately...can yah believe i only put about 350 miles on my car since feb 2001...and the last 150 were just with in the last week and a half....hehe...well yea i dont really plan on taking it out to sac raceway till i fix some safety issues and get use to the car more...but i have no $$ so i probably wont get it out till november
On my car, if I put jack stands on the sill behind the front wheels (in front of the doors) and let the front down, the rear comes off the ground. A lighter car spins less than a heavier car as there is less resistance to movement (inertia). Basic physics really.
paopao
Jul 28, 2007 08:43 PM
White S2k
Nov 13, 2002 12:33 PM
