help with 88 std hatch
I have a 88 std hatch that is throwing a code 16 in the ecu i do not know what this code is for i had a list of civic obd0 codes but have lost it.
The car will start missing really bad the i will take my foot off the gas and slowly get back into it and the miss goes away and then it will do it all over again a few minutes later. Does any one know what i should do.
Thank you
Thank you
http://www.phearable.net/tech/mil/troublecodes.html
Here is a link to all the trouble codes and their meanings.
Code 16 is infact Fuel Injector.
I have attached the page from the Factory Service manual that will give troubleshooting steps for this code.
Hope it helps!
Hope it helps!
would it be the same steps for a dpfi. There is no check engine light on only the code that flashes in the ecu. Could it be something else than a injector?
ecu, main relay, dizzy?
ok i did what it said and pulled the fuse to reset ecu and test drove code is gone and did not return however it still has a bad miss like before when hard on the gas ill take my foot off the pedal and slowly get back into it and no miss??????
It could still be a bad injector that is giving you problems. An automotive stethoscope is pretty handy for finding injectors that are not opening. You can hear a pinging noise from the injectors when they actuate when you place the stethoscope tip on them.
I had an injector start failing on a DPFI Civic and was able to use the stethoscope to determine what injector it was pretty quickly. I just revved the engine up a few times while listening to each injector with the stethoscope. When the engine revved up fine I could hear the 2nd injector kick in. When the engine wouldn't rev up as well I did not hear it ticking.
It was awhile ago so I do not remember exactly, but I seem to recall that it idled okay but occassionally when I would hit the gas from idle it would run rough and have no power.
818blue818
18
Sep 4, 2010 03:27 AM
