Help the Wannabe Mechanic...Valve Adjustment & Sparkplug Gapping
Alright folks, I'm getting ready to do my own valve adjustment and gapping of my sparkplugs. Can anybody tell me if I got the right tools for the job.
1.) Valve Adjustment Tool
2.) Feeler Gauges
3.) Sparkplug Gapping tool
[Modified by CPR, 8:09 PM 8/28/2002]
2.) Feeler Gauges
Yes you have all tools now go to :
http://www.c-speedracing.com/howto/v...lveadjust.html
or
http://www.helminc.com
Its very simple and make sure your car is cold when you do it.
or
Thanks fellas. A follow up question...
-How important is it to tighten the nuts to spec? I believe some of them have to be tightened to 5lbs/ft and others to 7lbs/ft. I don't feel like buying another torque wrench with that kind of accuracy. Can I just tighten them till snug?
[Modified by TodaSi, 9:23 PM 8/28/2002]
werd!...somebody get ready to call a tow truck for this man
Buy NGK plugs BKR6EVX-11 for example, -11 means already gapped to 1.1mm or .043. So, no need to gap, just check it
The part# you listed isn't the stock plugs that the ITR comes with does it? I have NGKPFR6G-11 as the stock ITR plugs. I was only going to buy the gapping tool because I've heard that a lot of the times, the gaps are out of spec.
Just be careful if adjusting the gap, lots of people crack/break the electrode tips which can lead to big problems down the road.
Do i realllly need a snapon valve adjustment tool.
My college budget doesnt agree with it. heh
Can I just use a wrench and screwdriver like in the manual?
for the others... you need the tool to make the job so much easier.
thats an expensive little valve adj tool. The specs for the intake valve and exhaust valve clearances are different, correct?
Check http://www.harborfreight.com, they have a valve adjustment tool set for pretty cheap compared to the Snap-On.
Ahhhhhh - my favorite store....their aluminum racing jack ROCKS!
Ok exactly how do you guys adjust the gap on the plugs. I just use the gap measure thingy to pry it larger. Am I a retard?
