f22a1 header
Old Oct 2, 2009 | 11:01 AM
Bright13's Avatar
Default f22a1 header
I bought a header for my '90 lx, f22a1. I removed the stock manifold and disconnected the down pipe from the cat converter and bottom of the engine, but when I went to pull it down and out of the car the flange that goes to the manifold wont go between the block and a crossmember. I even tried to pull it up through the engine bay, but the other flange is even bigger and also gets stuck. I would just cut it off, but I know that the header flange wont fit through there either. Is there a trick to this? Thanks.
BIGTUNA
Welding / Fabrication
Apr 21, 2008 04:07 AM
luv2drivecrx
Oct 19, 2005 02:14 AM
bootlegtrader
Aug 15, 2005 07:42 AM
sleeepy
Apr 3, 2003 01:42 PM
RACING INTEGRATION
Mar 15, 2003 08:09 PM
