Necessary to change H20 pump when changing timing belt?
Old Aug 28, 2002 | 03:54 PM
Quik Chris's Avatar
Default Necessary to change H20 pump when changing timing belt?
Hey guys, I'm changing a timing belt on a friend's '95 RS, he bought a brand-spanking new water pump to change when I change the timing belt... I'm pretty sure they don't go bad really, should I take the time and drain the coolant or just say FUGGIT?
Old Aug 28, 2002 | 04:29 PM
d-wreck's Avatar
Default Re: Necessary to change H20 pump when changing timing belt? (Midori Shinkansen)
replace it. its not really a matter of the breaking as much as leaking water and **** everywhere then causing you to be low on coolent.
if you got one do it, just cheap insurance
derek
Old Aug 28, 2002 | 07:17 PM
Nytecomm's Avatar
Default Re: Necessary to change H20 pump when changing timing belt? (d-wreck)
They basically come off together so why not? thats just my oppinion. Good luck!
Ennis555
Apr 11, 2017 09:21 PM
Jaydeep
Honda Civic (2001 - 2005)
May 24, 2011 04:07 PM
petrv
May 10, 2006 03:24 AM
1998hondaaccord
Sep 18, 2003 07:25 AM
garados
Oct 26, 2002 09:34 PM
