have two problems and I need help
What's up Honda tech I need help with my swap it's in but I have a check engine light battery light and my speedometer stopped working what do I need to do to fix them??? thanks.
are you obd0 obd1? pull the codes for the engine, your speedo cable might of taken a ****, or your speed sensor is bad, and your alt either might not be hooked up right or you need to replace it.
we need alot more info to help you in the right direction tho.
