just swaped gsr and smokin
Old Oct 1, 2009 | 10:26 PM
cubanteg16's Avatar
Default just swaped gsr and smokin
Hey everyone i just dropped my GSR in my EG...i changed out the pistons to type-r and thast about it...i put some old old cracked headers i had lying around, cuz i dont have any at the momment when i finally start the car for its first time it starts to smoke from the headers a thin white layer of smoke...help me out....plus everytime i rev my speedometer jumps like if it was the tack ....hit me up and help me thanx a bunch....
Old Oct 1, 2009 | 10:30 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: just swaped gsr and smokin
the smoking from the header will stop its normal what do you mean your speedometer jumps like a tach do you mean the rpm gauge check your distributer.
Old Oct 2, 2009 | 11:20 AM
cubanteg16's Avatar
bump...thanx man for the advice anyone else
Old Oct 2, 2009 | 12:00 PM
racebum's Avatar
you have to ask solid questions.
the smoke, if it goes away is header burn off. if it continues and is white it's a blown HG which is actually quite rare on a GSR since they are MLS. grime in assembly or someone trying to reuse the head gasket and or a warped surface or a combo of all could be that issue.
can't guess on the jumping, wrong year cluster, something unplugged. too many things to troubleshoot without knowing more
Old Oct 3, 2009 | 12:16 PM
cubanteg16's Avatar
idrivesideways---my spark plugs are like charcoal black and i looked down the spark plug journal and looks like oil in the piston...could this be valve seals???
Old Oct 3, 2009 | 12:44 PM
racebum's Avatar
charcoal is rich. wet slime is a problem. if you smell oil or see any it's rings, guides or seals. however, the first couple hundred miles the rings are seating so oil in the chamber can happen. if it doesn't clear up in 500 miles then something is up.
lcsej1
26
Feb 17, 2009 09:30 PM
leekor12
Jul 15, 2008 02:40 AM
leekor12
Jul 1, 2008 12:17 PM
AutoCross617
Jan 8, 2003 02:20 PM
R-1303
Nov 25, 2002 04:08 PM
