'95 Accord V6 (2.7L) oil capacity?
Old Oct 1, 2009 | 08:07 PM
xdhatcherx's Avatar
New User
Default '95 Accord V6 (2.7L) oil capacity?
Hi All,
New here. Have an old work horse Accord V6 for commuting that I bought off my brother-in-law. He lost the owner's manual for it and I have neglected buying a Hayne's manual for it (for now).
I searched around and found a thread where someone mentioned its 5 quarts to replace the oil in the V6 for oil change. I just wanted to see if someone could confirm that? Thanks so much everyone!
Old Oct 1, 2009 | 08:37 PM
nus_dogg's Avatar
Default Re: '95 Accord V6 (2.7L) oil capacity?
You can always start with 4.5qts of oil; fire it up for a min or two to see if there's any leak. Then shut if off; check the oil level and top it off so its full.
Old Oct 1, 2009 | 08:51 PM
xdhatcherx's Avatar
New User
That's basically what I did. I started off with 4 qts., let it get down in the pan and then checked the level. Still needed at least 1 more qt to get to the full line. I'm just double-checking if that's the appropriate amount so I'll know nothing serious is wrong
Old Oct 2, 2009 | 04:03 AM
minilowz's Avatar
its 4.6 qts with filter change in my owners manual (97 EX V6) I would check the level regularly, mine uses about a qt every 1000 miles or so. not dripping/burning. just using it.
btokfans
Transmission & Drivetrain
Sep 1, 2018 05:39 PM
hiya1432
Apr 5, 2013 12:27 PM
tractoriii
Dec 24, 2005 05:43 AM
rickytz7111
Dec 6, 2005 12:49 PM
Ludeboi
Oct 23, 2004 02:10 PM
