ls vtec????
hi im building an ls vtec mods are.
b16 head
crower springs and retainers
blox all motor valves
aem cam gears with ctr cams
minor port and polish
aem fuel rail with rc 310 injectors
stock intake manifold
b18b1 block
-Block has been decked
-Micro polish LS crank
-Shoped LS rods (To fit CTR Pistons)
-81mm CTR Pistons
-Block guard
-ARP Rod bolts
-ARP Head Studs
-ITR oil pump
-ITR Water pump
-ITR Timing Belt
question????
u guys think ill pass 200whp or not
b16 head
b18b1 block
-81mm CTR Pistons
-Block guard
-ARP Rod bolts
-ARP Head Studs
-ITR oil pump
-ITR Water pump
-ITR Timing Belt
question????
1 Grab a motor
2. look at it
3. toss as much money as you can on brand name parts
4. pray for hp
that's not how **** work buddy. plus there are 1.5gizillion threats about how much power m'i going to get.
is somebody down to design a honda engine dyno simulator like the V8 guys have?.. i can make some intense guap out of it..
2. look at it
4. pray for hp
Yes, it is possible to hit 200 whp with CTR cams in a 1.8L but takes some serious doing and it is not cheap.
i mean the fact still stands that the flame travel on those pistons is horrible, and you will have a very difficult time running decent timing.
i'm running 12:15:1 CR on my LSV and i'm running on Skunk2 STG. 2 camshaft w/ cam gears at +1,+1. so yes you should be able run higher lift cam. just clay your motor first. and it'll be hard to hit 200whp with just ctr cam. you'll need alot of tuning as mar778c stated. i only made 196whp with my setup and thats on STG. 2 cams but it was with a quick tune. with a little more in-depth tuning i should be able to reach 200whp, as another tuner told me. but i was too broke to go any longer. LOL.
What I'm referring to is the amount of air charge for combustion. The amount is the same because the vacuum for pulling in the charge, the piston size is still the same. The difference is the amount being pulled from the intake side versus the exhaust side. With the exhaust valve open longer, this will allow for the spent gases to be pulled back into the chamber. The spent gases introduce gases with act as inhibitors to the generation of a flame kernel.
I think you may be thinking of another concept. While dynamic compression is important, the state air for combustion is even more important.
Hey everyone, glad to be back...
Maybe it's me, and i'm not seeing 200hp on the current set up either, but wouldn't it be more efficient, cheaper even to just boost it at this point?
I mean you'd garuntee hit that 200 mark, hell go over that even AND might even save money depending on the Piston's you'd need for the goal + Labor.
