K20 swap on a 96' civic hatch
so lately i've been thinking about a k20 swap into a civic hatch... what do you guys think? should i start off with a ITR or a GSR engine or go straight for a K20?? i want something with decent HP that wont burn a hole through my wallet... so plz help!!
Good luck getting the K bar'd in cali.
IMO K's are overrated. Its a great motor but for the initial cost of the swap plus fabrication, you can have an H2B with cash left over.
Much harder. Hence why I say the cost plus fabrication is NOT WORTH IT. If you are asking if its harder than a B series you need to do more research. Not to mention a K is much harder to pass in cali than a B swap.
What is it exactly that is drawing you to the k?
Because its "baller status" or you just want decent power and torque vs the weak D?
If its power you want, build a B with the money you could save, or the H2B like I said. You can get an H22 for less than either and makes more power and torque than the B's
if you want something that isnt going to burn a hole through your wallet, then a k swap isnt the answer.
