help!!! civic eg!
Old Oct 1, 2009 | 03:03 PM
93-eghatch's Avatar
Default help!!! civic eg!
aight well i recent fixed my other problem.
So i started go normal speed so then like while i was pressing the gas it kinda started bogging out. like it didnt wanna go any more.. i let it out nd shifted gears nd pressed again nd it went.. but it does still nd is annoying. help anyone?? PLEASE!
Old Oct 1, 2009 | 03:48 PM
shawn_crx's Avatar
Default Re: help!!! civic eg!
what was your other problem...
bogging out most of the time it has to do with gas/dizzy/timing
Old Oct 1, 2009 | 04:52 PM
93-eghatch's Avatar
cause it was idleing.. i kno one is the iac but tho other one idk what it is. its shows up on iac also on auto zone. its behind the manifold.
i also replaced the throttle body..
but see before i replaced the throttle body, it wasnt bogging.. so then i put the other one bck on but the engine would shake wen i would rev it(and still did).then wit the new one it doesnt.
so it started bogging with the new one. lol
Old Oct 1, 2009 | 04:59 PM
shawn_crx's Avatar
So before changing the T/B it was working fine? You probably forgot to hook up a wire?
Did you mess with the MAP or TPS sensor? Did you put a new TB gasket?
Old Oct 1, 2009 | 06:11 PM
fryman's Avatar
Yea it could be that you don't have your distributor set in the right position....I would try advancing the timing some and see if that helps.
Old Oct 2, 2009 | 09:15 AM
93-eghatch's Avatar
well it wasnt working fine extactly. but it wasnt bogging.. before the engine would shake more. but with this one it doesnt.
i messed wit the TPS sensor. nd it stopped shaking. but not the map sensor.. how would i check it? or mess with it??
Old Oct 2, 2009 | 09:16 AM
93-eghatch's Avatar
i tried moving the distributor around.. but it didnt really do anything.
how would i move the timing?
Old Oct 2, 2009 | 09:52 AM
fryman's Avatar
Old Oct 2, 2009 | 10:38 AM
93-eghatch's Avatar
okay.. thanks you guys.. help alottt.. it doesnt do anymore..
galdo12
37
Sep 28, 2014 11:32 PM
AmbiguousCivic
Mar 27, 2013 09:09 AM
LavishTheKid
Nov 6, 2010 07:30 AM
Bakersfieldgsr
Nov 11, 2007 05:57 PM
wes7side5o
15
Mar 16, 2007 06:47 AM
