Real easy question?....
Old Oct 1, 2009 | 10:29 AM
chase7687's Avatar
Default Real easy question?....
I got a quick one to ask before I screw something up. I just bought some engine foam cleaner to clean my engine bay. What do I need to cover up besides the intake filter and what shouldn't I spray with engine cleaner/water?
I don't care if you call me a noob..... i just dont want to **** me car up!
Old Oct 1, 2009 | 11:00 AM
radex7's Avatar
Default Re: Real easy question?....
Noob or not, it feels totally sketchy to hose an engine bay, so I am with you on that. Here is my first and only experience I had with washing engine bay in my hatch... My carwash has an engine wash setting on its nozzle sprayer, and I wanted to check it out so I pulled in, covered up the distributer, alternator and starter with some bags. By the time I was done soaking it with the cleaner (it is dispensed with low pressure, and it smells like engine bright), only the dizzy bag stayed in place, but I was getting impatient so I said f* it, it is only 400 dollar car. I let it soak for a while while I was washing the exterior, then I just went back and hosed the thing . I tried to avoid the electrical components, but honestly - it is difficult. After I was done I realized the following: the longer you let it soak - the better, and pressure form the hose can strip your valve cover so be careful there. That's it! It started right up with no problems whatsoever! I am rather happy with the results. I can see my tranny now, and a lot of the gunk is gone. Good luck.
Old Oct 1, 2009 | 04:52 PM
durfeec's Avatar
distributor, air intake if you have a sri, fusebox possibly, battery thats all i covered up last weekend when i cleaned mine.
Old Oct 1, 2009 | 05:11 PM
.Manny.'s Avatar
Touching My Member
cover those things and dont spray directly at them and you should be okay
Old Oct 2, 2009 | 03:33 AM
chase7687's Avatar
ite..... i'm goona give it a try here in just a bit. just got off work so I am bored ...lol
I'm guessing a dizzy is a distributor?..... so i'm gonna cover that the intake, an my alterntator. I don't know where the fuse box is so that may be a problem so hope everything works.
Old Oct 3, 2009 | 09:37 AM
durfeec's Avatar
im assuming you drive the ef hatch in your avatar...maybe. if so its right on the pass side shock tower. its the black box with fuses in it. lol
Old Oct 3, 2009 | 10:35 AM
chase7687's Avatar
well i found out i had a cracked spark plug boot... so I did a slight tune up with new spark plugs, dizzy cap and rotor, and new plug wires. the only problem, I can't find wires to fit my zc.....!!!!!
Old Oct 5, 2009 | 10:01 PM
durfeec's Avatar
88-89 teg plug wires for a DOHC ZC
and if its a sohc i would prolly use z6 plug wires. plug wires are obd related. also if the plugs are on the backside of the head then the wires wont fit if you try to put them on a head with the plugs in the front side of the head. for example a6 plugs wires wont fit on a z6 head.
or you could just take yours in and match till you find the correct legnth. just make sure they come from a car with the same OBD.
civycoop
13
Jan 9, 2007 11:00 AM
realmc
Aug 9, 2005 09:20 PM
CSprogR34
14
Oct 20, 2004 08:37 PM
Si Arn
22
Mar 5, 2003 01:08 PM
