CRX A/C Wiring Need Help!
Hello, fellow CRX owners. Wanted to know if, anyone of you with a A/C CRX. Can take a picture of where your A/C harness is connected to when it enters the passenger side. There should be two connectors. I attached a diagram with the part I need a picture of below. I am currently installing A/C in my CRX and need this info. I found out where the small connector connects to. But, I'm having a hard time finding the other connection for the larger connector. Thanks in advance.
I installed AC a couple times, but LONG ago.
I do have the circuit diagram in front of me and I can tell you where and what it hooks up to.-
list the colors of the wires
AND
how many wires the connector can hold.
Do you have the dash switch plugged in?
Did you find the one wire connector that hook up to a wire going to ECU (bump up RPM when A/C is on)?
AND
AND
AND
Jonathan_ED3
Aug 28, 2004 11:18 PM
