ITB'S For D-series
Skunk2 intake manifold junked to have the flange, it's aligned pretty good.
- 44mm CBR 1000rr '06, with honda CBR TPS (the same, but only the connector, I welded 3 wires out of this, and connected to the actual wire harness, it work pretty fine.
- Vacuum lines, rubber couplers and collars: map signal, and brake lines. This setup have good power brake, and clear map vacuum from 4 cylinders.
- 4 CBR injectors + fuel rail, I did not plug itbs inejctors location, probably for a futur use, they still on Itbs, and they act as plugs.
- Brand new 4x 4'' velocity stacks from webber carbs, they're aren't fitted, but not big job.
- Brand new 4x pods air filter, have to be fitted.
- Custom gas cable bracket to use with oem honda gas cable.
$400.00 obo PLUS SHIPPING
Paypal only.
Paypal only.
H-powerd
Mar 19, 2007 07:28 PM
