whining noise help please
Old Oct 1, 2009 | 07:04 AM
AHHthatsJDMyo's Avatar
Default whining noise help please
my car (1994 civic ex- d16z6 completely stock) has been making a whining noise as i accelerate for a few weeks now. its kind of high pitched and you can hear it over the engine and driving noises through second gear. after second it still whines but you cant hear it because i hhave loud cheap tires.
a budy of mine thinks its the water pump but my water pump was replaced about 5k miles ago when i got the car.
also, i had a blown head gasket and warped head repaired less than 1k miles ago if that helps.
im going to call the mchanic that did the work on my blown head gasket and warped head today about this and a slight knocking noise that seems to be something hitting the timing belp or vise versa.
please let me know what you think
Old Oct 1, 2009 | 07:10 AM
red96civicex's Avatar
Default Re: whining noise help please
same thing happened to me on my old engine...it was the water pump
Old Oct 1, 2009 | 07:22 AM
was it a bad water pump or something to do with the timing belt not being tensioned right or what?
Old Oct 1, 2009 | 07:28 AM
well it happened actually 2 of my engines.
when i used to have a single cam, i replaced the water pump and timing belt myself, water pump was a bnib oem honda pump. and after i replaced it, it squealed. then when i got my old b16, it squealed when i put it in...so idk man. maybe it does have to do with the tension...
Old Oct 1, 2009 | 09:18 AM
Lasky's Avatar
my throw out bearing was bad in my tranny on my old Z6 and made a winding noise and went with the RPM's
Old Oct 1, 2009 | 10:34 AM
t.schultz's Avatar
thats exactly what i was thinking. my old motor did that.
Old Oct 1, 2009 | 11:25 AM
sounds expensive
Old Oct 1, 2009 | 11:34 AM
Lasky's Avatar
it shouldnt be that much considering you can get a full replacement clutch kit for less than $200 and the throwout bearing is just a small simple piece in that kit
Old Oct 1, 2009 | 11:36 AM
Lasky's Avatar
plus i never replaced mine.. the rings and valve seals went on the motor before the throwout bearing went.. motor had around 200K miles and rode the bad throwout bearing for the last 40K miles probably
Old Oct 1, 2009 | 04:18 PM
R666_EK's Avatar
I would assume either throwout bearing as previously mentioned, or your timing belt tensioner.
It is under a lot of stress after all. And if your belt and WP were just replaced with out doing the tensioner its possible its starting to whine. Its just a bearing.
Old Oct 1, 2009 | 04:20 PM
JayRSXS's Avatar
I romped 2nd gear at the track now its whining Oo
Old Oct 1, 2009 | 07:41 PM
thats what my buddies (recently ASE certified- i know it doesnt mean they are pros bu they know more than me) think it is. i didnt get a chance to call my mechanic today and i need the car for the weekend so ill prob. just be babying it for a few more days
Old Oct 1, 2009 | 08:24 PM
HondacivDX's Avatar
sound like the timing belt is too tight
Old Oct 2, 2009 | 06:28 AM
im hoping thats what it is. could that and the timing affect my gas milage? because ever since i got my car back its been like 5-7 mpg less than usual
Old Oct 2, 2009 | 04:40 PM
R666_EK's Avatar
Even if it IS too tight that doesn't mean the timing is off, unless it was installed and tensioned out of time already. (If that makes sense)
I would still put my money on the tensioner. When those go out they start to whine.
Either way I would take it back to the shop. But this time maybe try a different one.
Old Oct 3, 2009 | 06:35 AM
im going to take it back to the same guy because i have feeling that he did something wrond but he was really knowledgable so hopefully he can fix it for FREE
Old Aug 26, 2010 | 10:14 PM
thisisendless's Avatar
Did you ever find out what this issue was? Because it sounds like what my car is doing.
Thanks!
mooploops
Jul 29, 2009 11:42 AM
a_wishbone
May 3, 2007 11:22 AM
Ge-money
Sep 6, 2006 02:55 PM
riceburners1
13
Jun 2, 2004 10:57 AM
