CA exhaust ???
Old Oct 1, 2009 | 03:56 AM
m735is's Avatar
Default CA exhaust ???
I'm having trouble with my replacement exhaust. My 96 LX needs exhaust from the cat back. I usually go with Bosal replacements. They list two middle pipes, one for CA emissions and one for the rest of the country.
How do I know for sure which system I have on the car? Pre converter? A section of mesh flex pipe?
The car is NY now and I'm not the original owner.
Old Oct 1, 2009 | 04:12 AM
TheMuffinMan's Avatar
He knows where you live!
Default Re: CA exhaust ???
Have you CarFax'd it ever? 99.9 % chance if the car is in NY it was not a California car. To my knowledge there wasn't a difference between the two exhausts anyways. But I wouldn't order the CA one.
Old Oct 1, 2009 | 04:33 AM
m735is's Avatar
I looked up on Hondaautomotive parts using my VIN thinking that would tell me which I have. It also shows two versions. The CA exhaust does have a pre cat, so I I'll just look at mine and see if has one.
Old Oct 1, 2009 | 04:41 AM
Yeah, they all will give you the option for both
Old Oct 1, 2009 | 12:38 PM
Targa250R's Avatar
be professional
The difference behind the cat is in the length of the B-pipe and the style of flanges between the B-pipe and the muffler. CA emission cars use a shorter B-pipe and a flat flange for the muffler, where non-CA cars use a longer B-pipe and a bell flange for the muffler.
Old Oct 1, 2009 | 01:21 PM
m735is's Avatar
Fantastic, the original muffler is LONG gone. The one I pulled out from underneath was a welded pipe rig job (no flanges left).
Old Oct 1, 2009 | 02:24 PM
Targa250R's Avatar
be professional
The only way you'll be able to tell then is to look at the sections in front of the converter. California cars have a pre-cat in the A-pipe and use a stub pipe in between the A-pipe and the main cat that is about the same length as the cat itself. Non-CA cars use a normal non-catted A-pipe and a very short stub pipe.
California:
Non-California:
BTW, you may want to try a Walker B-pipe if you can find one. It's a little lower quality, but I've found that the Bosal B-pipes for '94-97 Accords have a lot of resonance and tend to buzz around 2200-2500 RPM while the Walkers don't. Only the '94-97 Accords seem to have this issue as I haven't seen it with '90-93 or '98-02 models. The Bosal mufflers are great though, and Bosal always stands behind the lifetime warranty on the mufflers without question.
Old Oct 2, 2009 | 04:10 AM
m735is's Avatar
Perfect description.
Thanks for the heads up on the "B" pipe.
I've used Bosal for years for that very reason, I take it back to Autozone and get a new one-no questions. I went through about 4 mufflers on my Civic, due to miles driven, not crappy quality. I'm on my third for my old BMW. I painted this one before I installed it, just because it's huge and a PITA to install. Four years and still looks new.
Thanks for the responses.
axis11
14
Dec 14, 2011 08:02 PM
B18Sleeper
Nov 3, 2005 08:01 AM
1hotcivicSi
Acura TL, RL & ZDX
Mar 31, 2004 11:39 PM
civic702
Aug 7, 2003 08:38 PM
